boneyardbanshee. Posted June 22, 2008 Report Posted June 22, 2008 Hey I have 30 mm D-slide carbs on a stock thumb throttle. I think I got the wrong one. It opens the slides all the way but there is about 1/2 inch of play in the throttle. Anyone have a part number that runs this setup? Quote
wesw Posted June 22, 2008 Report Posted June 22, 2008 the cables are adjustable either at the carbs or the throttle housing you should be able to get some slack out of it by the housing. Quote
boneyardbanshee. Posted June 23, 2008 Author Report Posted June 23, 2008 the cables are adjustable either at the carbs or the throttle housing you should be able to get some slack out of it by the housing. thanks got it. had to adjust it everywhere. on top the carbs, after the bend, and at the housing. seems to be ok but I hope nothing breaks seeing as though it is all about adjusted out all the way. My motion pro snaped right off the carb. For 60 bucks this thing better last. Quote
