mdhc500 Posted June 18, 2008 Report Posted June 18, 2008 For illustration purposes I have used a picture from one of xXBlessedWithDeathXx's threads... I hope you dont mind... When I put the Shee on jack stangs and grab the front tire at the 9 and 3'o-clock positions and pull with one arm and push with the other back and forth I get 1/4" tp 1/3" inches of lateral play where the (upper arm) J-arm bolts to the frame as indicated by the "BLUE" arrow. It is engough play that the J-arm will actually make contact with the spring. This is indicated by the "YELLOW" arrow. I assume the bushing or something in this assembly is shot? Also is it now unsafe to ride? If it is the bushing can anyone recommend a good set to replace them all upper and lower both sides? Also yes, all nuts are tight on all pivot points. Thanks guys... Mike :thumbsup: See photo below.... ----------------------------------------------------------------------------------------------------------- ----------------------------------------------------------------------------------------------------------- photo courtesy of: xXBlessedWithDeathXx (hope you dont mind) Quote
BansheeDan Posted June 18, 2008 Report Posted June 18, 2008 that is your arm bushings for sure. i have a full set of delron bushings that are brand new. if ya need em make me an offer Dan Quote
mdhc500 Posted June 18, 2008 Author Report Posted June 18, 2008 that is your arm bushings for sure. i have a full set of delron bushings that are brand new. if ya need em make me an offer Dan Dan, Will they work on the j-arm? I have an 87 j-on top a-on bottom... I assume since its just the bushing it will fit in the holes? and since its a j-arm setup I would need 12 correct? You can get the delrons online for like a buck, buck and a quarter per bushing... How many do you have? 16? Quote
BansheeDan Posted June 18, 2008 Report Posted June 18, 2008 Dan, Will they work on the j-arm? I have an 87 j-on top a-on bottom... I assume since its just the bushing it will fit in the holes? and since its a j-arm setup I would need 12 correct? You can get the delrons online for like a buck, buck and a quarter per bushing... How many do you have? 16? i am sure they are the same ...i have a full set of 12 15 shipped?? Dan Quote
mdhc500 Posted June 18, 2008 Author Report Posted June 18, 2008 i am sure they are the same ...i have a full set of 12 15 shipped?? Dan Send me your PayPal info Dan, I'll take em... Quote
