my bike wasn't getting spark so i tested everything turned out to be my coil,replaced the coil and everything was fine so i took the bike out rode it for about half an hour then it died again, took out a plug to see if i was getting spark and nothing, let it sit for a few minutes and then tried it again it fired up for a second and died again did this a few times and now nothing,CAN ANYONE HELP?
Edited by ws6
yes i still have the tors but they are not hooked up that's how i got the bike,as far as the stator goes i'll test it again just to make sure.
Ok yeah so now that you have known good coil on and if the stator tests out exactly within specs then I think the only other options are really going to be:
>short in the harness somewhere
>bad CDI (can't be tested) try switching out with a known good one
>bad flywheel (not very likely but possible)
>check for the wires up front under the tank that used to be plugged into the TORS brain box (2 wires that used to have a connector plug on the end) they should be connected to each other
hmmm... trying to think of any other possibilities...
thanks guy's appreciate the info,i'll check the wire harness cause now that you mention it, it started after i jiggled the wires, Hmmmmmm
