Well my setup is different reeds, trail port, complete rebuild including top and bottom, 60 thousants off the head, tors removel. Well I did my heat cycles 4 off them, and took her for a test ride not using more than half throttle. At first she's boogy, and the turbo boost hits. Hold the f@ck on! On the low end its boogy like it wants to go but doesn't and then its gone. Should it be more responsive? Set up at the moment from a&s is the air fuel is at all the counter clockwise. 260 jets and I think stock 25 mains? The needle is at its highest position. Idles great, just would like the low end to be a little responsive. Come pro's help a newb out.
Bro call A&S if they built the motor he Should be able to help you out, if not find a better builder cause you sure seem to have a BUNCH of problems from a FRESH built motor......
Well I only had him do the motor and carbs, he didn't have my quad. The problems I'm having at the moment is sinking the carbs. Which is why I think I'm booging on the low end. The problem is he's gone for the next two weeks. Don't need another builder, but can't get questions answered if he's gone. What bunch of problems are you talking about?
Check the squish....
Here's the problem.
Dan sets up his motors a certain way. I know he's out of town, and you can't get a hold of him, but to be 100% honest, I'd wait.
We could steer you easily in the 180 degree wrong direction compared to what and how he likes to run his setup.
If he shaved .060 off, depending on how he cut and chambered the head, 130 PSI sounds low to me.
Then again, if he ported the cylinders, depending on how he did them, that could be right.
So while I'm strictly guessing, he will KNOW....
To be honest, I'd wait and set it up per his spec.
