arfountain Posted May 12, 2008 Report Posted May 12, 2008 (edited) I am so confused. I had my shee running then I took the carbs out and put them back in and bang, no spark. I switched my CDI, Coil, on/off switch, key switch, and checked the ground. I used the parts off my running shee so I know they work. Still no spark. The only thing left is my stater, right? Any help would be very much appreciated. I am losing my mind here. She was running, then 15 minutes later, no spark. What the f***? Oh yeah, this shee does still have the tors, but I pulled the plug on them to make sure that wasn't the problem either. I know, it's time to rip them off this one too. Edited May 12, 2008 by arfountain Quote
Snopczynski Posted May 12, 2008 Report Posted May 12, 2008 did you unplug the tors module under the gas tank? none of the tors wiring ends can be touching each other either. Quote
arfountain Posted May 13, 2008 Author Report Posted May 13, 2008 did you unplug the tors module under the gas tank? none of the tors wiring ends can be touching each other either. I unplugged all of it, and still can't get spark. Quote
arfountain Posted May 13, 2008 Author Report Posted May 13, 2008 i swapped wiring the wiring harness and she fired right up. Go figure. Quote
