I have a 02 banshee and have been having clutch problems, sometimes when you ride it the clutch wont fully pull in like it is jammed up, but this changes from ride to ride. other days it will be fine, other days the clutch will pull normal but it will stay disengaged and when it finally engages it slips, so i pulled the clutches and they had a lot of meat left on them i put them back in as the manual says and still no luck any help would be great... thanks
check the cable those cables are like crap!!1 they wear off really quick and get stuck and the lever to water and lot of were can jam the thing if not that you say it have lots of meat!!??? buy new ones!!!
