I just finished installing a new chain, sproket, brake, brake rotor, etc. and now that i put everything on my axel seems to be loose, for example when i put it up on a jack i could move it up and down, so when i try to tighten the axel nut and rotate the back its to tight and doesnt want to rotate at all. So im guessing would it be the bearing that are messed up?
If so what kind of bearings would fit that bearing carrier, and what exactly would i need to do to install them and how would i put the axel back on right if thats not the case??
sounds like you need to replace the bearings.
what kind of bearings should i get? where would i order them from? and how would i put them on??
