i did a compresion check today. i can up with 165lbs. motor is a 350 on it's last bore w/ cool head and 18cc domes, i did the test with the motor cold, no carbs or pipes on it. i know i should warm it up firstbut i can't i'm wanting to run alcy fo i'm in the midst of changing carbs. does 165 sound right? and should i move to 17cc's to run alcy? and i'm at 1,266ft
