this might sound silly and im new to banshee mods and stuff but is there a difference between a long rod motor and a stroker motor sorry if this question sounds dumb but just trying to find out
Long rod = a longer con rod
Stroker = longer stroke from TDC to BDC
B
^^^^^^as well as a stroker crank with long rods. take a +4mm stroker crank with 115mm rods for example. long rods by them selves aren't really of much benefit. the longer 115mm rods help to offset the extra strain the +4 crank puts on the pistons and cylinders. an engine refered to as a long rod motor may also have a stroker crank. on the other hand there aren't many stroker cranks sold with a stock length rod either!
