Hey guys i was wondering what the thickness of the stock base gaskets are? I dont have any on hand to check. Also i picked up a 370 long rod motor with 10mm big bore sleeves in it, Will i have to run big bore gaskets or will standard ones be fine? Thanks.
They should measure around .027-.030 new depending on how hard your squishing them.
