Get your carrier all apart from the axle etc., then put it in the freezer for a few hours, take it out and if they don't come out fairly easy, hit the outside of the carrier with a heat gun for a little bit...
whatever you think is gonna be a bitch to come loose or off, soak it in PB spray over nite..then work on it the next day..
well i got my axle off and bearing and seals out but when i was taking the left nut off of the axle it fucked up the threads and i spent all day today trying to find the right die to fix the threads. Not only did i not find one i have to order the damn thing and it is going to take 2 weeks to come in :blink:
