Minkia38 Posted January 7, 2008 Report Posted January 7, 2008 Here are the stock parts I have for any year Banshee all parts are the price listed plus shipping, and yes, I combine shipping if you get them here I have many aftermarket parts as well, but those usually go up on ebay please email me at [email protected], my PM inbox here is always full or you can bid on ebay: http://motors.search.ebay.com/_W0QQsassZminkia38 Running Engine $900.00 Rubber intake boots/Boost $30.00 Reeds and cages $25.00 Carbs and cable $100.00 Airbox (or air filter) $50.00 Kickstarter $50.00 Gas Tank $40.00 Pipes $35.00 Frame components Frame $250.00 (title add $100) Steering stem $45.00 A-arms / J-arms $300.00 Swingarm $50.00 Axle $100.00 Bearing carrier $50.00 Footpegs $15.00 Nerf Bars / Heel guards $40.00 Rear Hubs $50.00 Rear Sprocket & Hub $35.00 Rear Brake disc & Hub $35.00 Dogbone $20.00 Rear Grab Bar $20.00 Front Bumper Pushbar $15.00 Shifter $10.00 Skid Plate $20 Plastic Front & rear Fenders $200.00 Radiator Plastic $35.00 Gas Tank Plastic $35.00 Seat w/ latch $75.00 Fender brackets $20.00 Electrical CDI Box $60.00 Wiring harness / Loom $50.00 Coil $25.00 Headlights $60.00 on/off switch $10.00 Key w/ plastic housing $40.00 Taillight $20.00 Misc Rear brake setup $100.00 Bolt set $40.00 Rear Shock $90.00 Front shocks $80.00 Front tires & rims $100.00 varies Rear tires and rims $100.00 varies Handlebars & grips $10.00 Clutch lever / perch $10.00 Thumb Throttle assembly $25.00 Radiator & Reservoir $50.00 Front brake lines $10.00 Front brake lever/rezzy $25.00 Motor Mounts $20.00 motor parts: cylinders $300 crank $200 shift drum, rods, forks $60 gears/tranny $110 cases $200 clutch cover $40 stator cover $ 20 stator + plate $70 internal bolts $30 head $20 flywheel $70 Quote
Minkia38 Posted January 8, 2008 Author Report Posted January 8, 2008 just listed some more stuff on ebay Here are the stock parts I have for any year Bansheeall parts are the price listed plus shipping, and yes, I combine shipping if you get them here I have many aftermarket parts as well, but those usually go up on ebay please email me at [email protected], my PM inbox here is always full or you can bid on ebay: http://motors.search.ebay.com/_W0QQsassZminkia38 Running Engine $900.00 Rubber intake boots/Boost $30.00 Reeds and cages $25.00 Carbs and cable $100.00 Airbox (or air filter) $50.00 Kickstarter $50.00 Gas Tank $40.00 Pipes $35.00 Frame components Frame $250.00 (title add $100) Steering stem $45.00 A-arms / J-arms $300.00 Swingarm $50.00 Axle $100.00 Bearing carrier $50.00 Footpegs $15.00 Nerf Bars / Heel guards $40.00 Rear Hubs $50.00 Rear Sprocket & Hub $35.00 Rear Brake disc & Hub $35.00 Dogbone $20.00 Rear Grab Bar $20.00 Front Bumper Pushbar $15.00 Shifter $10.00 Skid Plate $20 Plastic Front & rear Fenders $200.00 Radiator Plastic $35.00 Gas Tank Plastic $35.00 Seat w/ latch $75.00 Fender brackets $20.00 Electrical CDI Box $60.00 Wiring harness / Loom $50.00 Coil $25.00 Headlights $60.00 on/off switch $10.00 Key w/ plastic housing $40.00 Taillight $20.00 Misc Rear brake setup $100.00 Bolt set $40.00 Rear Shock $90.00 Front shocks $80.00 Front tires & rims $100.00 varies Rear tires and rims $100.00 varies Handlebars & grips $10.00 Clutch lever / perch $10.00 Thumb Throttle assembly $25.00 Radiator & Reservoir $50.00 Front brake lines $10.00 Front brake lever/rezzy $25.00 Motor Mounts $20.00 motor parts: cylinders $300 crank $200 shift drum, rods, forks $60 gears/tranny $110 cases $200 clutch cover $40 stator cover $ 20 stator + plate $70 internal bolts $30 head $20 flywheel $70 Quote
Minkia38 Posted January 9, 2008 Author Report Posted January 9, 2008 FREE SHIPPING tonight and Thursday night if you go through the HQ or email, (not ebay) on all items under 20lbs (in the USA) email me if you have any questions Quote
Minkia38 Posted January 14, 2008 Author Report Posted January 14, 2008 email sent Only one person took advantage of the free shipping! Oh well! Quote
