BaNsHeeJuNkEy Posted January 7, 2008 Report Posted January 7, 2008 I need a new cable so i got the stream line clutch cable. put it on the bike and i have maxed out all the adjustes on the bike and when i put it in to gear it still jumps and rolls slowley. has anyone had this problem and if so what did you do to fix it. Quote
[email protected] Posted January 7, 2008 Report Posted January 7, 2008 my clutch used to creep like that , i adjusted the little thing inside the center of the clutch. ( the ball crap thing ) Quote
BaNsHeeJuNkEy Posted January 7, 2008 Author Report Posted January 7, 2008 i never pulled the clutch apart before. it was fine last time i road it with the stock cable. do i have to pull the pressure plate off or is it just the nut and screw thing in the center. also what way did u go to adjust it. Quote
