theshee Posted January 3, 2008 Report Posted January 3, 2008 I am getting the odds and ends tied up on my build and am putting th carbs on ect... I am going to be running a 65mm bore cub with a 370 long rod crank, with 35mm PWKs. My altitude where it will be ridden is right at 8500 ft. I was thinking about starting with 155s on the mains, but im not reak sure on the pilot. What would you fellas suggest? I think my 421 cub had 158's on the mains and 50 on the pilots. Quote
sheerider1026 Posted January 3, 2008 Report Posted January 3, 2008 i have a stock stroke 68mm cub.. with 33mm pwk's.. i am running a 148 main, 45 pilots.. i can't say that it is spot on just yet.. i just have been messing around with my other shee, but i will get back to it. Quote
moneybags Posted January 3, 2008 Report Posted January 3, 2008 I was running my 421 cub (68Mill bore) at sand mountion Nevada with a 148 main and 48 poilet, at 4500 feet elevation. With 35 PWK carbs and CEL needels. I would start around their. Quote
theshee Posted January 3, 2008 Author Report Posted January 3, 2008 thanks.. ill start around there. :thumbsup: Quote
