WALLACE84 Posted November 7, 2007 Report Posted November 7, 2007 I just put a set of 35 pwks on my shee and I just got to start it yesterday(my pipe came back from rocket pipes) and she obviously not jetted in but everytime I rev it, gas comes up the hose for the powerjetts. What the hell is going on? this is the first tiem I have had carbs for gas but had powerjetts. Thanks in advance Quote
wesw Posted November 7, 2007 Report Posted November 7, 2007 they are setup for gas not alky right, if alky they wont run for crap on gas being they were drilled out. i would close the powerjet and work from there. unless your bike is a thirsty pig. Quote
WALLACE84 Posted November 7, 2007 Author Report Posted November 7, 2007 they are setup for gas not alky right, if alky they wont run for crap on gas being they were drilled out. i would close the powerjet and work from there. unless your bike is a thirsty pig. Yea they are setup for gas. I have the needles and all that for the alky in my tool box Quote
WALLACE84 Posted November 7, 2007 Author Report Posted November 7, 2007 so should I just pull out the powerjetts and epoxy over them? Quote
wesw Posted November 7, 2007 Report Posted November 7, 2007 just close them for now. ? why did someone put a powerjet on a gas carb usually dont need that much fuel for gas.?? Quote
WALLACE84 Posted November 7, 2007 Author Report Posted November 7, 2007 they used to be run on alky and they were converted over but they left the powerjetts on Quote
J-Madd Posted November 7, 2007 Report Posted November 7, 2007 they used to be run on alky and they were converted over but they left the powerjetts on Then the dump tubes were probably drilled out. Not sure how to fix that, or if you can get a fat enough needle to make up for it. If you can, let me know what you did....that'd be good info. Quote
