the problem i am having is the left cylinder is smoking normally and blowing air out and the right cylinder is suckin air in.... and also while it is runnin it idles fine but when i give it a lil throttle it revs real high on its own and i have to turn it off..... never heard of neone having these problems please HELP!!
not sure about the problem with the cylinders maybe it as something to do w the carbs not being in sync. but thats just a guess i really am not sure.
however i have had the throttle problem. i would chec the throttle line and make sure its not sticking anywhere. start at the thumb work your way down to the carb and evan check the slides on the carbs. this same thing happened to me when i was removing the tors system and put in a 2 into 1 carb.
hope this helps
what do u mean when u say the carb may not be in sync ?
not carbs, I think you already found your problem. Please use a propane torch with no flame and run around cylinder base to detect the leak. Them pull cylinder and replace gasket. If the case halves are leaking, you get to split them. It is common to have an air leak. The run on you experience is a tell tail sign and they do make a"special" sound with lean run on.
If this was a TORS problem, you would not have idle. If it idles fine and you can verify that both carb slide drop to the bottom of the carb throat, proceed with above testing.
Let me edit again. That would NOT even be a TORS problem but a carb slide or throttle cable problem. Everyone blames the TORS system because they do not understand it. It simply will trip out when there is something wrong. Removing the TORS, is just like solid fusing an electrical circuit because it keep blowing a fuse. There is a "reason" it blows. fuses do NOT blow for no reason.
Brandon
Edited by blowit
were you going to do what I told you?
Brandon
HAHHAHA :blink:
