T-daddy Posted October 29, 2007 Report Posted October 29, 2007 wen i pulled in the garage from riding earlier i noticed a leak under the bike i checked it smelled it then i put a towel underneath and seen pink and green fluid coming i think its coolant and tranny fluid can any one tell were it can be coming from Quote
dajogejr Posted October 29, 2007 Report Posted October 29, 2007 Flip the bike on the back grab bar, look at the clutch side cover. There's an oring that goes on the elbow pipe from the water pump to the back of the cylinder head. That's also where the gasket is for the side cover. otherwise, get some engine degreaser and brake clean, clean the motor off completely top to bottom, side to side...and see where it leaks from... Quote
T-daddy Posted October 29, 2007 Author Report Posted October 29, 2007 Flip the bike on the back grab bar, look at the clutch side cover.There's an oring that goes on the elbow pipe from the water pump to the back of the cylinder head. That's also where the gasket is for the side cover. otherwise, get some engine degreaser and brake clean, clean the motor off completely top to bottom, side to side...and see where it leaks from... allright will do thatnks for the advice will get back to u and let u no what i find Quote
