Leigh Posted October 3, 2007 Report Share Posted October 3, 2007 when i was rejetting i noticed a stick jammed into the carb.. it was on the right carb (not the one with the choke lever) but it was in the spot where the choke tube would go on the other side(facing away from the motor).. is this suppost to be plugged??? or could a stick just have gotten jammed into it some how.. Quote Link to comment Share on other sites More sharing options...
Leigh Posted October 3, 2007 Author Report Share Posted October 3, 2007 anyone know??? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted October 3, 2007 Report Share Posted October 3, 2007 Stick got jammed somehow. There should be a small piece of tubing from the choke on the left carb to the right... Quote Link to comment Share on other sites More sharing options...
Leigh Posted October 3, 2007 Author Report Share Posted October 3, 2007 Stick got jammed somehow.There should be a small piece of tubing from the choke on the left carb to the right... yeah i got the tube beteween the 2 carbs... but the hole it was in is on the other side like if threre was 3 carbs where the next tube would go.. Quote Link to comment Share on other sites More sharing options...
