Got one for sale if you're interested.
The good part about a dyna is you don't need a plate....unless you already have one. If you never get to program it, it has 4 preprogrammed curves that are pretty good for a stock motor bike.
To get the most out of it...programming software/cable and some dyno time should be used.
The Nitrous crowd likes them...cause you can program a fuel only curve, and a nitrous curve....
They have better/stronger spark signal, etc.
I'm selling mine because I don't have the time to dyno/tune mine in...and to be 100% honest, could use the cash for other projects right now.
180 shipped to you...instead of 250 to 300 brand new. Let me know...
I'm 99% sure it will...but you might have to swap (cut and solder/tape) the wire plugs off your old one.
Can you take a pic of the two plugs that go into your CDI (under the back grab bar, the big black box)..
This one has two, 4 wire outputs.
I think the 4 wire on your will plug in.
The 6 wire plug has two extra wires, they might be for the TORS, I'll have to look at a wiring for the newer bikes...though.
