This bike is perfect for the casual duner/play racer!! The motor was done within the last 9 months at F.A.S.T. Racing in Holton, KS.....I have all reciepts totalling over $3500.....It's a stock stroke 350 65mm cheetah cub w/ cleanup porting......It is a beast!! There is absolutly NOTHING that needs to be done to better itself, unless of course personal preferences.....it has the following:
*65mm Cheetah Cub cylinders w/ cleanup porting from FAST RACING
CPI inframes - small bore
35mm mikunis (tuned on dyno)
V-Force 2 reeds
Wiseco trued and welded crank to .001
513 series wiseco pistons
PD coolhead w/ 18cc domes
Marvin shaw rear competition shock
aftermarket plug wires
B9EGV NGK plugs
advanced timing plate
billet water pump impeller
15-44 gearing
lots of billet
+6 triple chromed swingarm
JJ&A carrier
21-12-8 10 paddle Haulers on rear
Dune Runners on Front
Trail Tech bars
Pingle fuel valve
New stater and flywheel
Billet clutch basket
FAST RACING CLUTCHES
new inner & outer hubs
much much more!!
TOO MUCH TO LIST!!!!
Call 785-259-0355 or email [email protected] or PM me....thanks!
Thanks sredish, I'm a bit suprised myself that I still have it....Oh well, it will go sooner or later....once somebody comes to view it, it will NO longer be available!! Thanks again.....
That's a nice, clean bike. :thumbsup:
