Mudd&Moo Posted August 30, 2007 Report Share Posted August 30, 2007 I just recieved a new FAST cluch form jeff and was wondering if I still need the cushin rings that go between the clutch plates and steel rings. Three I had were good and the others were shredded up. Quote Link to comment Share on other sites More sharing options...
Mudd&Moo Posted August 30, 2007 Author Report Share Posted August 30, 2007 Never mind after doing a search here i found out I dont need them thanks anyways Quote Link to comment Share on other sites More sharing options...
bk_banshee Posted August 30, 2007 Report Share Posted August 30, 2007 I just recieved a new FAST cluch form jeff and was wondering if I still need the cushin rings that go between the clutch plates and steel rings. Three I had were good and the others were shredded up. If your talking about the little black rubber rings, TOSS EM. you only want Steels and Fibers between fiber 3 and 4 you can add 2 steels if you have the room on a 7 plate. Quote Link to comment Share on other sites More sharing options...
