I have a weird oil leak coming from the front of the bike that drips onto the pipes I don't know where it is coming from or what is causing it any help will be greatly appreciated
I had a random oil leak too, never really figured out where it came from. Check the vent tubes, check to make sure your clutch side cover is on good. That's really the only 2 legit places oil could come from.
it's probably blowing out your exhaust flanges. there should be a rubber o-ring inside of the exhaust pipe that seals with the flange to prevent oil from coming out and seals the exhaust flow. i'm sure you can get replacement o-rings if they are shot or absent.
