tree454 Posted July 8, 2007 Report Posted July 8, 2007 I am looking for some info/advice on what carbs I should get. I am building a 421 Cub with clean up port, Noss 20cc, Shearer SB inframes, +5 timing. I have been looking at the PJ's and PWK's and wondering what would be the best set up. What are the advantages of PWK over PJ? What is the differance between a standard PWK and a Airstryker PWK. What are some other similar models with similar pricing. Thanks Quote
wesw Posted July 8, 2007 Report Posted July 8, 2007 you can get a set of pjs pretty cheap anymore compared to pwk 35s. they are about the same size adn what not. they are good carbs you just have to adjust the idle by turning the choke knob you will need a good carb sync tool, igot mine from jeff. it will help, honestly its a must for any banshee with 2 carbs. im not a fan of air strykers, the jetting is way different compared to reg pwk. so if you have some problems its hard to compare spec with other unless they run a/s. not saying they arent good carbs just different. Quote
