camatv Posted July 7, 2007 Report Posted July 7, 2007 i have my old cub top end its a 68mm for a 4mill stroker crank its clean ported and has used pistons, and a stock head thats set up for the cylinder the head has some marks from a crank letting go but is useable the cylinder has some very light damage in one of the transfer ports but has been ran since then and runs fine. the pistons are used but useable. i will include a new gasket set and the studs are installed, also includes the top nuts for the head. uses stock head gasket squish clearance is .52-58 depending on gasket.. set up for race fuel mix or alky.. i need 850 for all of it!! email or cfall me 620 259 6178!!! cameron Quote
camatv Posted July 9, 2007 Author Report Posted July 9, 2007 head nuts are acorn type.. yank your stocker 4 mill's off and slap this on you will gain quite a bit of power! Quote
