For sale is my wifes old quad. 91 blaster with new front brakes, new rear brakes. Needs new rear cable. New chain. fmf fatty with powercore. New air filter. boysen rad valve and reeds. two sets of rear tires. front tires are getting worn. rear tires are both on rims. vitos 240 kit. motor runs strong and the quad is pretty fast. makes some noise like the wrist pin assembly may be failing. Still has great compression. new carb and carb top. I also have to go with this quad. Another frame, 95 cr 250 motor and swingarm for blaster already cut for the motor. I have radiator, all wiring, carb, and everything to install. The exhaust i have is kind of rigged but it will work. I ran this motor with other frame for two seasons till the top end went. It is still stock bore and the cylinder walls are good. easily rebuildable and can easily be installed in either frame. I do not have title for this quad, bill of sale only. You may see my drivers license and whatever you may need. This quad has been in my family for years so I can guarantee clear title. Let me know if your interested. I would like to get 1,000 firm out of all the parts and the complete running quad.
