I had the same exact problem..... make sure your choke tube is in place and get rid of the tors. I got rid of the tors and it started in one kick and ran like a champ.... before it wouldnt run for shit and it would rev to the moon withought giving it gas
tors are gone
I think its a 99 there is no spark at all
WAS IT JUST A TOP END JOB, OR A FULL ENGINE REBUILD?
IF IT RAN OK BEFORE THE REBUILD AND HAD SPARK THEN MORE THAN LIKELY YOU GUYS MESSED SOMETHING UP. RECHECK THE FLYWHEEL, THE KEY WAY, THE WIRING CONNECTIONS FROM THE STATOR, THE COIL CONNECTIONS, the pickup, and any other wiring or electrical components you touched.
once put back togather it had spark but after I got it to fire a couple times it lost spark. I have completely rebuilt motors several times without anything like this happening.
Is it possible that the stator wires were routed in FRONT of the timing plate? The flywheel will rub the wire and eventually ground it. I had that happen once. Motor started and ran, then died and wouldn't start back.
Have you checked anything that's been mentioned already?
Check all the TORS connections, even if they're removed on the carbs.
Most importantly...make sure the two wires going to the parking brake/clutch lever are disconnected.
Then, check the stator and coil caps with an Ohm meter....
I dont think your getting this.
We need to know some things to help you look for the issue. We are not telling you that you dont know what your doing.
So was it a full engine rebuild or a top end rebuild?
