ok whenever i am hard on the go-fast button and shift the motor seems to miss. it will make a pop, fall on its face breifly then take of strong. this is all under full throttle conditions only letting off to shift. is this a needle adjustment or do i need to rejet everything?
yeah i did a plug chop and it seems to be good. insulator was white with a good ring at base and the electrode was "burnt" or whatever you call it to where it starts to bend back into the plug
I'm assuming you're using fresh plugs and fresh gas....
So..based on your ground crash skills, it's probably time to look at all the wiring, look for a shorted or pinched wire...
Bad kill switch/key switch, etc...
