The Faster Cracker Posted June 18, 2007 Report Posted June 18, 2007 ok whenever i am hard on the go-fast button and shift the motor seems to miss. it will make a pop, fall on its face breifly then take of strong. this is all under full throttle conditions only letting off to shift. is this a needle adjustment or do i need to rejet everything? Quote
dajogejr Posted June 18, 2007 Report Posted June 18, 2007 Backfire? Probably lean on your main....have you done a plug chop?? Quote
The Faster Cracker Posted June 18, 2007 Author Report Posted June 18, 2007 yeah i did a plug chop and it seems to be good. insulator was white with a good ring at base and the electrode was "burnt" or whatever you call it to where it starts to bend back into the plug Quote
dajogejr Posted June 18, 2007 Report Posted June 18, 2007 yeah i did a plug chop and it seems to be good. insulator was white with a good ring at base and the electrode was "burnt" or whatever you call it to where it starts to bend back into the plug I'm assuming you're using fresh plugs and fresh gas.... So..based on your ground crash skills, it's probably time to look at all the wiring, look for a shorted or pinched wire... Bad kill switch/key switch, etc... Quote
