I was wondering if someone could point me in the right direction? I have an 05 banshee... Port & Polished, 4mil long rod stroker crank on stock cyclinders boyseen reeds k&n clamp on filters and a Noss head. Anyone got an idea on the domes I need for this set up? any help would be appreciated. and also what carbs I need for this set up. Thankx Justin
Probably Race gas this is pretty well gonna be drag race only. but I might run pump Thanks for your help
For pump gas you're looking at 22 or maybe 21cc's, depending on if you've got any timing advance or not. For race gas, go as small as you want, but keep in mind that higher compression = more frequent rebuilds.
Probably or you might. Since you can't decide, you may want to mix? In that case, go with 19. It just happens that I have a barely used set of them. Let me know if you're interested.
