bansheeryder_69 Posted June 6, 2007 Report Posted June 6, 2007 where is the best place to pick up bearings for the banshee. I need the rear hub bearings. thanks. DILLON Quote
FireHead Posted June 6, 2007 Report Posted June 6, 2007 where is the best place to pick up bearings for the banshee. I need the rear hub bearings. thanks. DILLON Rear hub bearings? Really? I am assuming you mean rear axle bearings, in which case the Pivot Works kit from RMATV is the only way to go. :thumbsup: Quote
woodwardspecialties Posted June 6, 2007 Report Posted June 6, 2007 we carry all balls bearing kits Click here as well as pivot works Click here Quote
bansheeryder_69 Posted June 7, 2007 Author Report Posted June 7, 2007 Rear hub bearings? Really? I am assuming you mean rear axle bearings, in which case the Pivot Works kit from RMATV is the only way to go. :thumbsup: well the rear left hub is loose as a goose and I thought it would be a bearing, am I wrong? Quote
shanYE west Posted June 7, 2007 Report Posted June 7, 2007 (edited) well the rear left hub is loose as a goose and I thought it would be a bearing, am I wrong? The rear hubs ride on splines and are tighted by the castle nut on the hub. If the nut is tight and you still have play you should pull the hub off and check the axle splines and hub for wear/damage. Edited June 7, 2007 by Fouledout420 Quote
FireHead Posted June 7, 2007 Report Posted June 7, 2007 The rear hubs ride on splines and are tighted by the castle nut on the hub. If the nut is tight and you still have play you should pull the hub off and check the axle splines and hub for wear/damage. Word. Out of curiousity, exactly how loose is a goose? :ermm: Quote
okbeast Posted June 7, 2007 Report Posted June 7, 2007 Word. Out of curiousity, exactly how loose is a goose? :ermm: You know when they start cacklin and makin all kinds of racket.....that's when you've taken it too far :ermm: Quote
bansheeryder_69 Posted June 8, 2007 Author Report Posted June 8, 2007 anyone know where i can pick up a good axle? Quote
MILO Posted June 8, 2007 Report Posted June 8, 2007 when my axle bearings were shot, the sprocket hub and rotor were both a little loose and the axle nuts were tight. the axle and hub splines were fine. new axle bearings tightened everything right up. :cool: Quote
FireHead Posted June 8, 2007 Report Posted June 8, 2007 anyone know where i can pick up a good axle? eGay? :ermm: Quote
