brian25 Posted June 5, 2007 Report Posted June 5, 2007 left side dosnt line up right side is on am i doin smething wrong. Quote
dirt-riceburner Posted June 5, 2007 Report Posted June 5, 2007 You prob already know but there is a L and R stinger. Might wanna double check. Quote
brian25 Posted June 5, 2007 Author Report Posted June 5, 2007 You prob already know but there is a L and R stinger. Might wanna double check. yea i can take the one on the right and put it on both sides, but the one with the "L" markings dont fit on either side Quote
peterlocal22 Posted June 5, 2007 Report Posted June 5, 2007 on the one that doesnt fit, unbolt the silencer from the stinger, then keep the stinger in the same location and rotate the silencer a bit and then screw back into the stinger tube but at a differnet position than originally started with. Continue to try this until you have done a complete 360 rotation of the silencer and your back to the same spot as you started with. Let me know if this doesnt work or let me know if what im saying is unclear? im bad at explaining things, lol. good luck, peter Quote
