I have a banshee that is bored .20 over full port and polished with t5s has carbs off a 2004 not sure wat the jets or main pilot is at need help on what i should do i was told its jetted for sealeval and i live in wa a little bit above sealevel but go back and forth betweeen riding up here and goin to florence and coos bay. Cant seem to get a sweet spot up here dont no if i should set it back to stock jets and main pilot?? Any help would be great thanks
Except for porting I have pretty much the same setup and my carbs are jetted with 300 mains and 30 pilots with the clip in the middle using stock needles. My pilots are a little rich but it does great with that setup. I think that with porting you might need bigger mains. Others here will chime in also with their setup. Just need to work with it until you get it right. Good luck!!! :biggrin:
I forgot to mention that I have filter pods and not an airbox.
