i recently just re-rung my banshee and before i did that it ran perfectly and started easily. since then it wont kick start but if i roll start it, it will fire right up. after it get warmed up it will start, but if i let it sit a while then i have to roll start it again. anyone have any suggestions?? help me
I had that same problem about 3 monthes ago...
But after i would bump start it a few times it wouldnt start at all after..
it was like it wasnt getting any gas through it...
so i checked the spark it was getting spark...
then i checked the air hose above the gas cap and it was kinked
it wasnt letting air come through to the tank...
check it out might help might not...
-Shane
i think i figured it out! i forgot to put the choke tube back on. i will get a new one tomorrow and see if that helps. im pretty sure this is why it will not idle and start up.
most likely your problem ^
