mercado111 Posted April 4, 2007 Report Posted April 4, 2007 Trade for a yfz450 or TRX450 and some cash. 535 cheetah motor 10mm stroker crank Ported by A&S Sheare out of frame drag pipes(bare) V-Force 3 Direct Drive Lock-up clutch K&T 2-5 overirde trans. 38mm Carbs(gas) K&T upgrade coil Front Marvin Shaw Coil over shocks Rear Comp. Marvin shaw Shock +14 Metal tech Swing Arm (honda style carrier) Aluminium oversized radiator K&T Aluminium gas tank with dual pingel Skat trak 12 paddle buffed rear tires Front buffed tires have extra set of 39mm carbs and fuel pump that can be converted to Alky PM me with any questions or more pictures Located in so. cal Quote
mercado111 Posted June 4, 2007 Author Report Posted June 4, 2007 bump. Will take $3000.00 for the motor. Quote
