Need to replace my bulbs but cant seem to get the lights to open. I removed the screw on the bottom but I'm guessing theres something else holding it together, just dont want to break something!
1.Remove the headlight mounting screw and pull the headlight out of its housing.
2.Pry the rubber cover away from the bulb socket. then turn and disconnect the socket from the headlight.
3.Remove the bulb from the headlight housing.
You should invest in a CLYMER book on Banshee's,it answers alot of question.
