May Posted February 4, 2007 Report Posted February 4, 2007 i just picked up a set of 34pjs on gas what do i need to change to go to alky thanks Quote
dajogejr Posted February 4, 2007 Report Posted February 4, 2007 Larger pilot, drill out the mains, drill out the dump tubes...and add a power jet. Sizes to drill vary a little ...based on the mods for your engine, temps, elevation...etc. Someone here can give you some ideas where to start. Also, you do know with Kehins if you drill out the dump tubes, you can NOT go back to gas, those tubes are not removable.... Also...you want to think about fuel delivery, several ways to do it, depending on what you're using the bike for. Dual pingel valve, bigger float bowls, removing a float and a fuel pump are all methods used widely... Quote
