For sale is a 95 Drag Banshee with the follwoing Mods.
535 cheetah ported by A&S
10 mil stroker with TZ bearing(crankworks)
V-Force 3
Direct Drive lock-up Clutch system
2-5 Overide cut by K&T
38mm Air strikers (gas)
Shearer out of Frame Drap pipes
K&T after market Coil
Metal Tech +14 chromoly swing arm( honda style carries)
12 Paddle buffed haulers
Front smoth buffs on Douglas rims cut by direct drive
Front Marvin Shaw Coil overs
Rear marvin Shaw Comp
K&T Aluminum Fuel tank with Dual Pingal
Oversized Aluminum Radiator
Chorme: A-arms(stock), swing arm, spindles, stering stem.
Frame and hubs poweder coated candy Red
extra set of 39mm carbs with Fuel pump (can be convertered to Alky)
$8000.00
