mercado111 Posted January 24, 2007 Report Posted January 24, 2007 For sale is a 95 Drag Banshee with the follwoing Mods. 535 cheetah ported by A&S 10 mil stroker with TZ bearing(crankworks) V-Force 3 Direct Drive lock-up Clutch system 2-5 Overide cut by K&T 38mm Air strikers (gas) Shearer out of Frame Drap pipes K&T after market Coil Metal Tech +14 chromoly swing arm( honda style carries) 12 Paddle buffed haulers Front smoth buffs on Douglas rims cut by direct drive Front Marvin Shaw Coil overs Rear marvin Shaw Comp K&T Aluminum Fuel tank with Dual Pingal Oversized Aluminum Radiator Chorme: A-arms(stock), swing arm, spindles, stering stem. Frame and hubs poweder coated candy Red extra set of 39mm carbs with Fuel pump (can be convertered to Alky) $8000.00 Quote
