Clutch was acting like it was slipping took it apart and have
2 broken steels.It's a hinson clutch and basket w/ hd srings.
Gonna order new fibers and steels just need to know what torq
for spring screws also how to tell if I adjusted the center screw
for the shaft correctly.
Thanks in advance
Thanks in advance
Spring bolt torque is 7.5-8 ft lbs. 7.5 i believe.
adjust the center screw until the lever on top of the case lines up with the arrows on the case in front of the sprocket area. I like to keep it alittle torward the stator side.
