GSXR1000 Posted January 17, 2007 Report Posted January 17, 2007 Clutch was acting like it was slipping took it apart and have 2 broken steels.It's a hinson clutch and basket w/ hd srings. Gonna order new fibers and steels just need to know what torq for spring screws also how to tell if I adjusted the center screw for the shaft correctly. Thanks in advance Quote
FASTOYS Posted January 17, 2007 Report Posted January 17, 2007 Clutch was acting like it was slipping took it apart and have2 broken steels.It's a hinson clutch and basket w/ hd srings. Gonna order new fibers and steels just need to know what torq for spring screws also how to tell if I adjusted the center screw for the shaft correctly. Thanks in advance Spring bolt torque is 7.5-8 ft lbs. 7.5 i believe. adjust the center screw until the lever on top of the case lines up with the arrows on the case in front of the sprocket area. I like to keep it alittle torward the stator side. Quote
