yfz450 Posted January 12, 2007 Report Posted January 12, 2007 Ok, this isn't banshee specific but I'm sure you guys can help me out. I'm looking to put a Ninja 250 twin into a Warrior chassis. The Ninja uses a push-pull throttle setup. What this means is that their is 1 cable to pull the slides open and 1 cable to help close the slides (safety feature). I want to use the stock thumb throttle on the warrior but I need a cable that will allow me to keep the thumb throttle and use a cable for a set of dual carbs - so I thought a banshee cable might be a good choice. The problem is that I need the cable for a set of carbs that have had the TORS removed and all that other crap on top of the stock carbs. The carbs on the Ninja are Keihin CVK30's if that helps. Anyone know which cable I should look for? I am guessing that it's the throttle cable for a set of stock carbs with the TORS removal kit installed but want to be sure before I order anything. According to Motion Pro's website I need part number 01-0813 - Fits stock thumb throttle to Keihin PWK 28 & Mikuni TM 28 carbs. Use with stock carbs requires 2 carb caps (01-0023) and 2 adjusters (01-0013). Use with stock carb eliminates TORS and stock carb caps. Requires idle kit (08-0045) when used with stock carbs. FYI - I called Motion Pro and they won't make me a custom cable because it goes outside the original design of the Ninja motor and there is a very slight chance the slides may stay open. It's a liability thing. So now I need to do my own research. Thanks in advance for you help and input. Quote
dajogejr Posted January 12, 2007 Report Posted January 12, 2007 This is a LONG Shot, but...there is a place called Sport Mart in Clinton Township MI. They make or can get just about every single thing for snowmobiles known to man. I'm pretty sure if you can give them dimensions and the end types/sizes/styles that need to be, they can probably make you a cable. However, I've never personally seen a push/pull thumb throttle, I'd bet that will be your biggest hold up. Quote
yfz450 Posted January 12, 2007 Author Report Posted January 12, 2007 This is a LONG Shot, but...there is a place called Sport Mart in Clinton Township MI.They make or can get just about every single thing for snowmobiles known to man. I'm pretty sure if you can give them dimensions and the end types/sizes/styles that need to be, they can probably make you a cable. However, I've never personally seen a push/pull thumb throttle, I'd bet that will be your biggest hold up. A friend just explained the push/pull setup in a little more detail. Sounds like I'll be going twist throttle. Quote
