i had a 100w rickey stator bolt broke off and tear itself to shreds.
put stock stator and new flywheel on and i have to use carb cleaner
to get it to fire and it will run fine at 1/2 choke but will not run without
for crap without choke unless you are at higher rpm pickup coil is gapped at .20
the stator is used but test ok any help please?checked compression both cyl. have
170 psi.
170 psi.
When the damage occured did it mess up your crank seal at all? You may want to check that first.
