maggot Posted November 17, 2006 Report Posted November 17, 2006 Need help with my shee. Recently overhauled the motor running it in and the other day it just started miss firing or some thing. Checked my coil and CDI both fine. Unpluged the throttle switch too. The thing is it idles perfect but as soon as I open the throttle it sounds like it doesnt get feul or enough spark. Is there anyone that could maybe help me. :: Quote
RNBRAD Posted November 17, 2006 Report Posted November 17, 2006 Make sure the little tors black box is gone. Next make sure your crossover tube is connected and make sure you have no leaks. Do a leak down test if you haven't already. Do those things and if it doesn't fix it then let us know. Quote
maggot Posted November 18, 2006 Author Report Posted November 18, 2006 Make sure the little tors black box is gone. Next make sure your crossover tube is connected and make sure you have no leaks. Do a leak down test if you haven't already. Do those things and if it doesn't fix it then let us know. Thx Ill try that. Ill come back 2 u. :thumbsup: Quote
