What do you guys think about the pvl ignition, I just put one on my drag bike that was on one of my other bike's. Everything was good, then all of a sudden one side quit fireing. Is there anyway to tell whats wrong, I checked to wires going into the coil. So basically is it junk now, or what are my options.
nice bike
no clue on the pvl,there some guys that run them on here. is the coil on that side bad??
Not much help but why dont you check your plugs and replace them :shrug:
I run a pvl, more then likely i would say its you coil.
FIND OUT WHAT SIDE QUIT GO TO THAT COIL AND TIGHTEN YOU THE SPADE CONNECTORS ON IT HAPPENS ALL THE TIME IF THAT DOSENT FIX IT AND YOU FIND NO SHORT GET YOURSELF A COIL BUT THEY DONT GO OUT VERY OFTEN
