jason_kfx400 Posted October 9, 2006 Report Posted October 9, 2006 help i have an 2000 banchee with fmf fatty pipes after i put these on [new pipes] i have no low end what so ever my jetting is 300 main 25 pilot neddle set on third slot with holes drilled in air box lid it back fires too badly this my first two stroke so any advise will help Quote
dajogejr Posted October 9, 2006 Report Posted October 9, 2006 Temps you ride in? Elevation you ride at? Does it still have the TORS on it? I'd bet one of four things... TORS is screwed up. Choke tube fell off or is not in place Carb Slides are in backwards Carb float bowls are switched..... Quote
jason_kfx400 Posted October 10, 2006 Author Report Posted October 10, 2006 Temps you ride in? Elevation you ride at? Does it still have the TORS on it? I'd bet one of four things... TORS is screwed up. Choke tube fell off or is not in place Carb Slides are in backwards Carb float bowls are switched..... well i live in western ny so a say elevation is about 1500 feet temp was 70 degrees or higher and yes it has tors on it [ is there a way to remove without speeding money] thanks Quote
dajogejr Posted October 10, 2006 Report Posted October 10, 2006 Remove them without spending money? No. Disconnect them electronically so they don't function? Yes. Do a TORS Removal search by [email protected] He already has a thread with pictures. I think you're fat on your main jet...but, check what I've recommended....then, if a plug chop still shows rich/lean, adjust your main accordingly. http://www.dfn.com/benkaren/plugchop.html Quote
nameehsnab Posted October 12, 2006 Report Posted October 12, 2006 Carb float bowls are switched How do you know which is which? Quote
dajogejr Posted October 12, 2006 Report Posted October 12, 2006 Stock carbs, the left carb has a choke on it. That same float bowl has a tube leading up it to feed fuel to the right carb via the "Fuel enrichening circuit".... The right carb bowl doesn't have the tube in it. Aftermarket carbs are different, they both have that tube but for overflow purposes.... Quote
nameehsnab Posted October 12, 2006 Report Posted October 12, 2006 Thanks! This last weekend I was down at little sahara OK and I was having probs with the shee starting. I just ported the cylinders myself(race logic template) and cleaned and rebuilt the carbs. I noticed that the carb bowls were not the same. Every morning the bike would not want to start. once you got the bike started it ran fine. wile riding you would have back fire every so often. I will look into the carbs now. Quote
