Hi everyone, i know most of you are far ahead of me on tunning and mods but yesterday i found a cheap mod that can be usefull. It work for a K&N filter on a stock airbox. You can make an adapter plate for that aftermarket filter by using the stock filter cage and plate. Its easy as taking whatever tools you like to cut hard plastic, first you cut the outer ring on the plate where the foam filter seat and take care of not cutting the inside ring. Then you cut the cage like frame that support the foam filter, some handsanding for finishing and there you have a perfect fit for you K&N filter or a spare plate. Hope it will help some people who just get the addiction of the Banshee.
