Hi all
I'd like to get a noss cool head with 20 or 21 cc but right now I dont have money to do that...
Would it be a good idea to mill my stock head? i run 91 octane fuel... how mm to mill if its a good idea? I suppose my 91 octane fuel doesnt help me for compression... will it change anything for jetting to mill the head... i suppose that it doesnt change the carb flow but I prefer to ask :baseball_w00t: so tell me all what you know about the subject and that you think I must know!
(I know I already made a thread about cool head sorry to post a new one but I'm confused)
thank you all!!
What compression are you at the way it sits right now? First, you need to find that out.
Depending on where you're at (elevation)...you could probably go .020 and be ok.
.020 over.
You shouldn't have to change jetting if it's correct now...but, it's gonna run hotter, keep that in mind with more compression.
Check your plugs if you do shave you head.
i'd install milled head at same time as I'll install my temperature gauge so I suppose that I'll see it on my gauge and can stop engine when it's in the red
with 120 compression right now if mine is shaved I think there would be a problem no?
Will I be able to run 20 cc domes when I'll get my noss cool head or I'll be better with 21? with 91 octane fuel... I'd like to know cuz I'm makin my futur set up on paper to know how it will cost and what i have exactly to buy thank guys :baseball_innocent:
