endofitall9 Posted August 19, 2006 Report Posted August 19, 2006 what kinf of throttle cable do I use for a graydon 2 into 1 system with a 35mm keihin pwk, went and picked up one today from the local shop they gave me one from a cr500 but it is way off to much cable not enough housing..........thanks Quote
endofitall9 Posted August 19, 2006 Author Report Posted August 19, 2006 thanks alot wallrat, I knew you ran this setup should have pm'ed ya just didn't know the the slide end would fit the keihin pwk slide... I'll pick one up tomorrow Quote
differentstrokes Posted August 19, 2006 Report Posted August 19, 2006 You can get one from trinity, I think they're around $35 bucks and the cable is braided. Terry Cable makes them so they're good quality. Quote
Snopczynski Posted August 19, 2006 Report Posted August 19, 2006 Cascade Innovations is where I got mine, but, I think it is a Honda 250r throttle cable. Quote
Dmcbanshee Posted August 19, 2006 Report Posted August 19, 2006 I bought a stainless braided Terry cable (Blaster cable) for 35$ for my 35mm 2 in 1 PWK. Quote
endofitall9 Posted August 20, 2006 Author Report Posted August 20, 2006 the blaster cable simply will not work atleast the one i got today won't, is there some kind of magical trick i need to do to make this thing work? Quote
Wallrat Posted August 20, 2006 Report Posted August 20, 2006 Nope, mine bolted right up. What's not fitting? Oh and that terry cable has to be the stiffest piece of shit I've ever tried. Quote
endofitall9 Posted August 20, 2006 Author Report Posted August 20, 2006 they gave me the factory blaster cable I guess its for the TORS and such but they were the only shop around that even had a blaster cable, so I guess I'm going to have to order the tors elim. kit for the blaster to get the cable or can you just buy the cable without having to buy a tors elim kit? Quote
Wallrat Posted August 20, 2006 Report Posted August 20, 2006 First one I had was a terry cable from Trinity. Then I replaced that ASAP with a motion pro cable for a blaster. I run a twist throttle though so maybe I grabbed one of their cables for their twist kits. Quote
