is it worth having and the cost of it ,would i see any performance gain.what do you
guys think about it and would i have to change my carbs i currently have 30mm and i was told i would have to re do my porting all over again.
No its not worth it.It will make the transferrs smaller and there already a bottleneck.You will gain very little if any with bigbores and you would be better off with a good port job for a little more than the bigbore cost you could get a cub and see some real gains.
i had vitos 404 big bore kit in my old shee, and the thing was far better than stock,, probably not nearly as good a cub or even a good ported motor, but i gave me more bottom end response, and was pretty good on the top too
they are good overall kits , however the builder who did my 10 mill . Showed me why they are not good . 1 , the transferport exhuasts : the walls are so thick that the flow is not as much as a normal cylnder .From the knowledge i gatherd, Its not so much about cc's and more about flow.
