Dmcbanshee Posted July 29, 2006 Report Posted July 29, 2006 I need info on cheetah 400cc.A friend sale his cheetah 400cc powervalve stage 4 ported.Come with 2 set of dome,v-force2.Need new 68mm pistons. He asking 1300.00USD for, it's a good price?And I have a stock basket with barnett clutch this is rather stong setup???And I think my single carb (35mm PWK)suck with this motor need dual 35mm carbs.And I want to run this motor on MX track and trails is it much better than a stock cylinders Thanks Quote
Big Blue Posted July 29, 2006 Report Posted July 29, 2006 (edited) As long as you have the stiffer clutch springs it should hold fine. Does he have the PV's with it also? That with the combination of your single carb it will have quite a bit of power down low. As long as everything you will need is there it is a good buy. https://id304.securedata.net/trinityracing....?products_id=85 Edited July 29, 2006 by Big Blue Quote
